Date/Time: Tue, 14 May 2024 05:13:19 +0000
Large Volume Trade Indicator
View Count: 652
[2017-03-24 10:28:21] |
trader46 - Posts: 18 |
Can you add option to marker alignment for Center. If using on non-bid/ask bars is difficult to tell which bar the volume occurred on
[2017-03-24 17:12:03] |
If you set the Draw Mode Input to one of the Circle options, it will be center aligned.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-24 17:12:28
[2017-03-24 22:49:20] |
No it plots right or left only
[2017-03-25 01:08:37] |
OK we have to look at this again.
