Date/Time: Mon, 29 Apr 2024 16:05:27 +0000
Stochastic formula for spreadsheet
View Count: 2197
[2013-08-16 17:55:42] |
robwa - Posts: 5 |
I need to produce logic for two stochastic indicators on a spreadsheet. The last bar values will be different from the SC stock indicators. One formula will use my predicted range bar high to calculate the stochastic at that price level, and the other formula will calculate the value for the predicted low. I could do this by using the SC formula and replacing the appropriate values for the last bar in the calculation. Is it possible to find the formula SC uses to calculate the spreadsheet columns for the stochastic indicator? |
[2013-08-16 18:14:38] |
Sawtooth - Posts: 3983 |
Take a look at these: http://stockcharts.com/help/doku.php?id=chart_school:technical_indicators:stochastic_oscillato http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s21 |
[2013-08-17 00:04:48] |
You can the source code for the Sierra Chart stochastic studies in the /ACS_Source folder in the folder Sierra Chart is installed to on your system.
