Date/Time: Wed, 15 May 2024 15:10:10 +0000
Control Bar 1 to 8 have same text colour - Is it possible to customize the color for each
View Count: 652
[2017-03-24 07:21:38] |
User186889 - Posts: 53 |
Hello Sierra I have attempted over 2 hours of frustration to set up 2 Control bars (CB) CB1 is for DARK background + LIGHT text CB2 is for LIGHT background with DARK Text But If I change the text color on CB1, it changes the text color on CB2 and the button color on CB2; and vice versa Is it a case that each CB (1-8) all call on the SAME database so I can not have different color text or button on each CB? I also don't appear to be able to have 2 different text buttons on the same CB to allow this option Is this all the case - Or am I doing something wrong? Thanks - Mark |
[2017-03-24 09:01:34] |
The Control Bar Button Properties are consistent among all of the different Control Bars that can be configured. If it is as flexible as you want, then it increases the frustration for other users who do not require this because it takes more set up. We do not know what you mean by this: I also don't appear to be able to have 2 different text buttons on the same CB to allow this option
