Date/Time: Thu, 02 May 2024 10:43:14 +0000
Zigzag Study - Duration (# of bars) between Reversal Prices not working
View Count: 2305
[2013-08-16 17:27:59] |
SherKhan - Posts: 19 |
Hello, Please look at attached image. I am trying to plot # of days elapsed between the high and low swing of zigzag study. Even when the option is turned on, the study displays 0 value. Let me know if I am missing anything here. Thanks |
Zigzag Study-Duration Issue.png / V - Attached On 2013-08-16 17:27:40 UTC - Size: 46.95 KB - 527 views |
[2013-08-17 03:41:46] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1013, when available.
[2013-08-17 07:57:55] |
Thanks a lot Al. If the bar duration is going to provide time elapsed between the swing price, then please add the following attributes to zigzag 1. # of Bars between the swing 2. % change in reversal price 3. Slope - Points per bar Thanks |
[2013-08-19 21:45:53] |
Hello Al, SC Developer I just downloaded the 1013 update and was very excited to see the duration value for Zigzag being displayed. But I am not pleased with the value calculation. On a daily chart or any bar chart, shouldnt the Duration show # of bars elapsed between the zigzag swing ? Take a look at the chart attached...The value marked in yellow is the actual value which different than what zigzag displays. May be I am not understanding what is meant by the duration here. Please help me understand. Thanks Parag Date Time Of Last Edit: 2013-08-19 21:47:04
Zigzag Study-Duration Issue 2.png / V - Attached On 2013-08-19 21:45:38 UTC - Size: 56.26 KB - 518 views |
[2013-08-19 21:49:24] |
The duration is in days. Another user asked for Number of Bars, which will be added in an upcoming version.
[2013-08-19 22:06:57] |
Thanks Al. Have you looked at my previous chart ? I have a daily chart with zigzag on it with duration option. Would you please take a look why the zigzag number is not matching the # of trading days ? Are you counting weekend days as well ? For historical chart, I dont see the option to load weekend data enabled in chart settings. |
[2013-08-19 22:23:41] |
Also, can you also add an option to zigzag to display as a Histogram ?
[2013-08-20 22:26:51] |
Al SC Developer, Were you able to reproduce the issue I marked in the attachment "Zigzag Study-Duration Issue 2.png " ? Thanks |
[2013-08-21 03:53:36] |
When available, ver 1014 will have new option to display number of bars for ZZ.
[2013-08-24 05:55:23] |
Al SC Developer, Thanks for the changes. I can now see the # of bars between high and low of zigzag swing. But these newly added attributes are not being written to spreadsheet study. I should have mentioned that in my previous post. Could you please make sure I can extract this data into spread sheets ? Thanks Date Time Of Last Edit: 2013-08-24 05:55:35
[2013-08-24 14:51:50] |
The new subgraph will be exposed in ver 1016, similar to how reversal price and line length are today.
[2013-08-29 17:12:05] |
Thanks Al. I was able to extract the data in spreadsheet. Perfect.
[2013-09-03 17:24:12] |
Recent posts reviewed.
