Date/Time: Mon, 20 May 2024 18:06:40 +0000
Force Login/Logoff
View Count: 1065
[2017-03-22 21:41:12] |
User513959 - Posts: 16 |
Hi I was wondering if there is a way to force a logoff from another instance to enable login on another computer. ie. Main desktop is logged in to SC, then want to log into my laptop. Logging into my laptop forces the desktop to log off allowing me to properly connect on my laptop. So far it looks like I just get a continual connect then disconnect. Thanks
[2017-03-23 00:02:50] |
There is no way to remotely control Sierra Chart's connecting to an external data feed. We do have the ability to allow Sierra Chart to be used on more systems temporarily if you are getting locked out of Sierra Chart itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-23 02:07:26] |
Thanks for getting back to me. Just so I understand properly, I would have to log off at my desktop beforehand in order to gain access to my data feed via my laptop?
[2017-03-23 02:20:33] |
Yes that is what is required by CQG.
