Date/Time: Tue, 14 May 2024 22:11:27 +0000
SC with AMP futures account
View Count: 1858
[2017-03-22 16:09:37] |
User61576 - Posts: 418 |
can you pls explain how i can use SC to trade both manually and automated with my AMP account? AMP requesting me to use rithmic or CQG why can't i use use SC feed? or iqfeed? |
[2017-03-22 19:05:52] |
Please use CQG rather than Rithmic. You can also use the Sierra Chart Exchange Data Feed for data: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php However, be aware that the cost of exchange fees is much higher if you are not using a trading account: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingCost Refer to this page for information about manual trading: http://www.sierrachart.com/index.php?page=doc/Trading.html For automated trading, refer to: http://www.sierrachart.com/index.php?page=doc/AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-22 19:10:22
[2017-03-23 21:59:52] |
lets say i want to trade manually and also track simulated trades (same chart book, different charts) can i trade live on 1 chart and simulated in another for the same symbol? must i use different SC instances? |
[2017-03-24 03:11:44] |
For what is described in #3 you need to use separate instances of Sierra Chart for this. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
