Date/Time: Sat, 18 May 2024 07:25:41 +0000
incorrect when I duplicate
View Count: 660
[2017-03-21 21:12:44] |
User634276 - Posts: 12 |
here the picture of the function "chart, duplicate chart" 3tick range chart bar whit my indicator Do you have issue? |
duplicate chart.png / V - Attached On 2017-03-21 21:12:03 UTC - Size: 44.21 KB - 227 views |
[2017-03-21 22:23:40] |
For our position we cannot answer this at all. We do not know indicator you are referring to, who programmed it and why it is not working the same. You are in a better position to answer the question than we are. So why is there a difference in the result? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-21 22:24:22
[2017-03-22 01:30:13] |
The real probleme I found it is on the candel in first rectangle. Candel is not same and that cause trouble my indicator In the second rectangle, that is my indicator I create and dont have opinion on that too. |
duplicate chart.png / V - Attached On 2017-03-22 01:30:02 UTC - Size: 44.21 KB - 233 views |
[2017-03-22 02:21:41] |
OK we see now. We thought there might have been a difference with the candles but it was a little hard to tell because the charts were not lined up perfectly and the rectangles were partially covering the bars. Go to each of those charts and select Chart >> Reload and Recalculate. Do they then look the same? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-22 03:56:55] |
I Apoligy, I dont resolve it by Chart >> Reload and Recalculate I try same time Chart >> Reload and Recalculate in speed less than normal and I see not difference too I saw that on many chart I duplicate on Bar period Type : Range Per Bar-Standard (in ticks) "3" , some it is when market is too fast Dont know if its same on other bar period type and really, I dont have opinion more than that but now you know Thx |
[2017-03-22 19:17:27] |
Therefore, there should not be any difference between the chart bars of two different charts if the settings are the same for both of them. At this point, provide us the Chartbook file following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Tell us the Date-Time and time zone of one of the chart bars you notice is different. We just need to know one of them, this is all. Also make sure Sierra Chart is set to a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-27 00:35:44] |
Hi, I just now found finally what was wrong, On New Chart IN CHART SETTING >> ADVANCED SETTINGS >> CONTINUOUS CRONTRACT was different of other chart so volume was not ajusted |
[2017-03-27 01:00:50] |
We do not see how this is possible because we have verified that, that setting is copied when duplicating a chart.
