Date/Time: Wed, 02 Jul 2025 05:26:43 +0000
Support for an Art project based on market data
View Count: 1584
[2013-08-16 08:41:17] |
Shaharabin - Posts: 28 |
Hi guys, I guess this is quite unusual but I'd like your help with a little project i want to do. I want to drive a set of lights based on the market activity, for this i want to send some bits from the PC's parallel or serial port from sierra chart. I have some knowledge in programing (i wrote a custom trading system for sierra chart), i guess i can write a custom study with some functions that sends the data i want to the port but I'm not sure how to do that. can you please advise with what functions i need to use? maybe some lines of code to get me started... Thank you, i promise I'll send some pictures once it's done. |
[2013-08-17 01:38:58] |
This is outside the scope of our support. Other than that you will need to use the Windows API. We recommend using Visual C++. Here is the documentation: http://www.sierrachart.com/index.php?l=doc/doc_VCExpress.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
