Date/Time: Sun, 28 Apr 2024 03:22:51 +0000
Numbers Bars - Volume hidden behind bars
View Count: 651
[2017-03-18 22:33:21] |
pipsmart - Posts: 15 |
Hello, I would like to have Volume displayed in the foreground and bars displayed in the background. Can you advise how to do this? Right now the ABDiff Profile in my Numbers Bars are displayed in the foreground and blocking the Volume numbers partially. Please advise. Thank you. |
[2017-03-18 23:27:44] |
This is not making sense to us because the numbers will always be in the foreground. What studies are on the chart? Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-18 23:28:04
[2017-03-19 00:02:21] |
Please find the chart below. http://www.sierrachart.com/image.php?Image=148988170292.png Thank you. |
[2017-03-19 00:05:31] |
There are no other studies. Its only Numbers Bars with 'Volume' Number Bars Text and 'ABDiff Profile' Background Type. Thank you. |
[2017-03-19 00:30:35] |
The problem is you are using both a Background Coloring Method and Text Coloring Method. Set the Column 1 Text Coloring Method to None. This will solve the problem.
