Date/Time: Mon, 29 Apr 2024 06:26:52 +0000
Unresolved external symbol > example SCSFExport scsf_HurstExponent(SCStudyInterfaceRef sc)
View Count: 1516
[2017-03-18 21:00:26] |
b3cker - Posts: 34 |
Unable to compile example SCSFExport scsf_HurstExponent(SCStudyInterfaceRef sc) from studies7.cpp What includes am I missing? added fallowing includes from studies7.cpp to my dll and got an error --> see below #include <iterator> #include "sierrachart.h" #include "scstudyfunctions.h" #include <vector> //error 1>wt_gann.obj : error LNK2019: unresolved external symbol __CrtDbgReportW referenced in function "public: float & __thiscall std::vector<float,class std::allocator<float> >::operator[](unsigned int)" (??A?$vector@MV?$allocator@M@std@@@std@@QAEAAMI@Z) 1>libcpmtd.lib(stdthrow.obj) : error LNK2001: unresolved external symbol __CrtDbgReportW 1>C:\SierraChart\Data\wt_gann.dll : fatal error LNK1120: 1 unresolved externals ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ========== |
[2017-03-18 23:29:55] |
Are you performing the build through Analysis >>Build Custom Studies DLL?
[2017-03-18 23:33:59] |
I am using MS c++ studio.
[2017-03-19 09:02:28] |
Refer to step 11 here: https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php#ConfigureProject Make sure you use the debug version of the Runtime library. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-19 15:41:56] |
"Make sure you use the debug version of the Runtime library." Please see the attached Thank You |
sc_error_snap.PNG / V - Attached On 2017-03-19 15:41:15 UTC - Size: 52.46 KB - 325 views |
[2017-03-19 20:13:50] |
That is not the setting the documentation makes reference to. Refer to step 11 here: https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php#ConfigureProject Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
