Date/Time: Sun, 05 May 2024 09:32:08 +0000
Update data ascii file in SC
View Count: 641
[2017-03-18 17:49:18] |
b3cker - Posts: 34 |
I have many datasets longer than it is available in SC. I was able to import ASCII files into SC(copy to /data). Is there a way to get data updated by SC? For example my SPX dataset goes back to 1950. |
[2017-03-18 18:00:52] |
Yes, make sure the filenames use the same symbols that Sierra Chart uses which are listed in File >> Find Symbol and that the filename has the file extension dly.
