Date/Time: Tue, 07 May 2024 21:04:55 +0000
SC search function
View Count: 555
[2017-03-18 14:31:46] |
User12089 - Posts: 350 |
1. Is there a manual menu function which accepts a timestamp as param and positions/scrolls the chart to the position of the timestamp regardless of how many e.g. days / session ago the place is on the chart 2. Is there API for the above 3. When a custom SC study is running on historical data e.g. when loaded for the first time can it pause when it finds a pattern of interest so the chart remains positioned at the corresponding place and the study proceeds to the next place / data only after the user presses e.g. a button |
[2017-03-19 09:00:10] |
1. Refer to: Chart Menu: Goto Date/Time (Chart menu) 2. Refer to: ACSIL Interface Members - Variables and Arrays: sc.ScrollToDateTime 3. No not at all. Nothing like this would ever exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
