Date/Time: Wed, 15 May 2024 00:39:47 +0000
Are these automations possible with ACSIL?
View Count: 698
[2017-03-16 20:41:05] |
phaedonk - Posts: 352 |
I'm looking at ways I can enhance my manual trading with ACSIL, before trying for full automation. Are the following doable? If not, maybe a version of them? If yes, are they very hard for an ACSIL newbie to eventually program? 1) I enter an order manually, with attached stop and two targets. ACSIL will move the first target so it is at, for example, 1R (i.e. target in ticks = risk in ticks). If I then move the stop, the first target will be re-adjusted. But, if I then move the target manually, nothing will happen. 2) This site ( http://electroniclocal.blogspot.com/2014/11/order-flow-automated.html ) has an interesting take on semi-automation that I'd like to try: in essence, have a button (on the toolbar?) where if I manually press it, then ACSIL will start looking for available trading opportunities per its code. There could be a button for shorts, one for longs, or some other consideration. He states: "There are buttons on the top line that arm the algo so that when the conditions are met, the order is triggered. I can arm and disarm the algo with one click when I see a trade setting up. It only goes off if in fact the trade does setup." Thank you. |
[2017-03-17 10:10:45] |
Yes all of this can be done. Refer to: Automated Trading From an Advanced Custom Study Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events We do not know whether it would be difficult for you or not. That is not something we can reasonably answer from our perspective. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
