Date/Time: Thu, 16 May 2024 18:48:46 +0000
Trade Mgmt Study - Color Bar
View Count: 640
[2017-03-16 12:07:35] |
User104854 - Posts: 441 |
Can the TMS study be used with the color bar study? I'd like to trail a stop behind particular color bars but can't get it to work. I'm able to draw a line, stair step, or whatever with my color bar study and it shows the exact points that it'd work. Please advise. Thank you.
[2017-03-16 18:37:32] |
Yes this should work. As long as the Color Bar Based on Alert Condition Study is outputting the correct values.
[2017-03-17 01:33:43] |
I got it working. So awesome! Appreciate it.
