Date/Time: Thu, 16 May 2024 15:08:15 +0000
Skip or disable history load for specific symbols
View Count: 495
[2017-03-16 09:40:32] |
User183877 - Posts: 2 |
Is it possible to configure Sierra not to download historical data from remote feed for specific symbols? I use custom calculated values written directly in *.scid datafile so it stores like this for example: SPY.scid SPY-INDICATOR1.scid SPY-INDICATOR2.scid (external proprietary software do the calculations). and so on for other symbols. And when switching between SPY/XLF/XLE/... Sierra always try load history data for all respective ***-INDICATOR1/2/3/X symbols and it delays history load for actual symbol - im trying to avoid this. Sierra loads 1 symbol history at a time as i understand, so i need a way to avoid this custom symbols load attempts. // FYI last chapter here mentions remap to alternate datafeed: Chart Data and Chart Data Files // can i remap this symbols to <No-service> feed? // where remap procedure is documented? Date Time Of Last Edit: 2017-03-16 09:47:52
[2017-03-16 17:35:38] |
No it is not possible to prevent the historical data download but maybe we could add a symbol setting to control this which would be set through Global Settings >> Symbol Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-16 17:36:17
[2017-03-16 17:36:52] |
is it possible to download history in more than one thread?
Date Time Of Last Edit: 2017-03-16 17:37:08
[2017-03-16 18:18:28] |
No it is not and that would not be added.
