Date/Time: Sat, 27 Apr 2024 11:46:39 +0000
SC 959 : I have problems with this message
View Count: 2140
[2013-04-02 17:05:35] |
salsem - Posts: 43 |
Hello Support SC TT Gateway Status: Fill server for the ICE_IPE-A exchange is Open | 2013-04-02 12:59:37 The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\C.Book11-CC,KC..cht | 2013-04-02 12:59:48 Thanks in advance |
[2013-04-02 18:24:12] |
Is that Chartbook file set to automatically open? If so, then remove it through Global Settings >> General Settings >>Files to Open on Start Up. Delete this Chartbook: C:\SierraChart\Data\C.Book11-CC,KC..cht It appears to not be valid. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-02 18:24:24
[2013-04-02 18:28:27] |
Charts book will not open ! numbers from 1 to 10 is fine chart book 11-12-13-14 not opens please help The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\C.Book11-CC,KC.cht | 2013-04-02 14:20:33 The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\C.Book12-CT,SB..cht | 2013-04-02 14:21:07 The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\C.Book13-BRN ,GAS.cht | 2013-04-02 14:21:20 The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\C.Book14-HE ,LE.cht | 2013-04-02 14:21:34 |
[2013-04-02 19:04:49] |
It appears these Chartbooks are no longer valid. Something has likely gone wrong with saving them on your system. Please use backup Chartbooks as documented here: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
