Date/Time: Sat, 04 May 2024 07:15:21 +0000
Rithmic - How to Enter Option Symbol
View Count: 2069
[2013-08-15 14:10:58] |
umair1 - Posts: 86 |
I wanted to trade an option on the british pound futures. The symbol in Rithmic is: 6BU3 P1510.CME It's a 1.51 Strike put expiring Sept 6, 2013. I tried entering 6BU3-P1510-CME 6BU3P1510-CME but SC wasn't able to find the symbol. What is the correct way to view the chart for this symbol? --- Also this is one case where I have to run R|Trader side by side with SC because I don't know where to find the option symbol names in SC. It would useful if SC could have a window that shows all the options like they do in R|Trader and most other platforms (see attached) |
rithmic-options.png / V - Attached On 2013-08-15 14:09:36 UTC - Size: 81.21 KB - 585 views |
[2013-08-15 18:43:19] |
This would be the symbol format to use: 6BU3 P1510-CME One thing you need to be certain of is to determine how many spaces between the 3 and P. You need to verify how many spaces there should be. You may want to try 2 spaces or more. We will see about getting list of options from Rithmic to choose a symbol from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-15 18:51:53] |
I get the following when I put a space in: HD Request # 423 - Received 1 record and wrote 0 records for 6BU3 P1510-CME | 2013-08-15 07:32:47 The chart is blank and shows no grid or bid/ask lines. |
[2013-08-15 18:56:42] |
Provide a copy of the complete message log by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-15 20:52:24] |
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6BU3 P1510-CME.scid | 2013-08-15 13:51:30 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6BU3 P1560-CME.scid | 2013-08-15 13:51:37 Starting updates for: 6BU3 P1560-CME | 2013-08-15 13:51:37 HD Request # 429 - Downloading Intraday chart data for 6BU3 P1560-CME to the file 6BU3 P1560-CME.scid. Service: rim | 2013-08-15 13:51:37 Compressing file: C:\SierraChart\Data\6BU3 P1560-CME.scid. This may take a while... | 2013-08-15 13:51:37 Rithmic GSP - Requesting historical Minute data. | 2013-08-15 13:51:37 HD Request # 429 - Received 1 record and wrote 0 records for 6BU3 P1560-CME | 2013-08-15 13:51:38 HD Request # 429 - Intraday download COMPLETE for 6BU3 P1560-CME | 2013-08-15 13:51:38 Real-time intraday chart data file updates started for 6BU3 P1560-CME | 2013-08-15 13:51:38 |
[2013-08-15 23:42:06] |
What this means is that there is no historical data being provided for the option symbol. Data received in real-time will be charted though.
