Date/Time: Thu, 16 May 2024 07:51:05 +0000
[Programming Help] - Study Subgraphs Diff. Display
View Count: 551
[2017-03-13 20:26:49] |
User104854 - Posts: 441 |
I created a study where it calculates the difference between Yesterday's Close and Today's open on the ES. I want to display the value in text. I've figured it out but it displays the value on every bar. Is there a way to display the text just once per session? Ideally I'd like to have the value just above the 'Today's Open' line. I've attached a screenshot. Please advise. Thanks.
Gaps.bmp - Attached On 2017-03-13 20:26:36 UTC - Size: 2.49 MB - 197 views |
[2017-03-13 21:56:45] |
You will need to contact a developer to do this. This is also an advanced usage question which is not within the scope of our support. Contact edgeplayer _AT_ edgeplayertrading.com Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
