Date/Time: Wed, 08 May 2024 15:07:16 +0000
How to distinguish Flex Renko from Universal Renko in ASCIL?
View Count: 847
[2017-03-13 15:29:28] |
DabbaDo - Posts: 146 |
I see sc.AreRenkoBars(), but is there some way to discover which of the four Renko bar types are on the chart? Thanks, Dale |
[2017-03-13 17:50:51] |
No, there is not. This kind of capability will be done sometime this year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-18 12:13:30] |
FYI and FWIW to anyone who cares about this, the distinguishing name does exist in GetStudyName(0). Here is some code I use to pull it out. Not tested on every kind of symbol, so YMMV. I could have done more error checking, and Sierra Chart may break this with future changes, of course. void GetContinuousContractAndBarsPeriodTypeCodes(SCStudyInterfaceRef sc, SCString& ccCode, SCString& barsPeriodType)
{ SCString thisName = sc.GetStudyName(0); // like ESM7 [CB] Flex Renko 32-31-1 #5 --but Continuous None gives no [] std::vector<char*> tokens; thisName.Tokenize(" ", tokens); SCString token0 = tokens[0]; if (tokens.size() < 3 || token0 != sc.Symbol) { ccCode = barsPeriodType = "INVALID"; return; } auto token1 = tokens[1]; int barsPeriodStartIndex; if (token1[0] == '[') { ccCode = token1; barsPeriodStartIndex = 2; } else { ccCode = "[C0]"; barsPeriodStartIndex = 1; } for (size_t i = barsPeriodStartIndex; i < tokens.size() - 2; i++) { barsPeriodType += tokens[i]; } } |
[2017-03-18 18:45:19] |
It definitely does!This is an example of what you will get: ESH17 1 Min #1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
