Date/Time: Wed, 15 May 2024 21:31:43 +0000
Open Trading DOM with 1 click
View Count: 1110
[2017-03-12 00:51:18] |
User150371 - Posts: 70 |
Is there a way to Open Trading DOM with 1 click ? The only way I can see to open it is File > Open Trading DOM > etc., which is time consuming. It would be good to be able to place a button on the Control Bar which Opens and Closes a Trading DOM for the symbol on the chart currently open. Thank you.
[2017-03-13 17:13:26] |
We will see about this. You can always keep it open and minimize the Trade DOM if you want to keep it out of the way. And once you save the Chartbook and reopen the Chartbook, it is open and available. It can also remain in a minimized state. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-13 17:15:45
