Date/Time: Sun, 19 May 2024 16:10:03 +0000
fatal error while building dll
View Count: 742
[2017-03-11 10:08:18] |
User30743 - Posts: 364 |
hello, i have been trying to set up a custom study in visual c++ - i followed exactly what is here http://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php but it keeps returning a fatal error and i have no idea why and what is wrong and how to repair it - can you hel me please. this is the message in the output window |
[2017-03-11 23:11:26] |
Looks like the problem will be resolved with Build >>Rebuild Solution from within Visual C++.
[2017-03-30 18:42:19] |
No, it was not resolved.. i still have this mistake message.. althought i did everything according to the tutorial
[2017-03-30 19:09:56] |
i mean, now i found a solution on the web .- i desabled incremental linking and it suceeded - the question now is . can it be like this? can i DISABLE INCREMENTAL LINKING? will it work properly? i am a complete newbie in c++ and visual studio so that is why i am asking. i have no idea what incremental linking is, but it seems it did its job. please feedback if it is ok to have it like this |
[2017-03-30 19:10:13] |
File attached
fatal error.png / V - Attached On 2017-03-30 19:10:08 UTC - Size: 74.38 KB - 211 views Attachment Deleted. |
[2017-03-30 19:38:37] |
You do not need to use incremental linking. In a small project it offers no practical benefit. We can see that the build is now successful from the screenshot. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
