Date/Time: Wed, 15 May 2024 00:11:24 +0000
Drawings No Longer Copying to DOM
View Count: 694
[2017-03-10 19:24:28] |
User188637 - Posts: 2 |
Hello, One of my favorites features in SC is the ability to copy drawing from other charts. I use this with the DOM and price levels. For example I put a a blue line for the overnight low or high on my main chart, and then I can see it on my trading DOM. I believe this happened when the indicies rolled over yesterday. I am using this with the ES(June 17 contract). I am not sure if I had the drawings yesterday morning, but I am pretty sure, so maybe I did have them right after I rolled over - point is it may have nothing to do with rollover. Yes the symbols for the two charts are the same, and I have restarted SC. I made sure the Hide Drawings & Hide Drawings from other other charts for the DOM Window was not accidentally checked. Not sure what else to check. Also the other charts in the chart books also copy the drawings from the specific chart , and they show up correctly. Thanks, Dan |
[2017-03-11 23:56:54] |
This issue is due to symbol differences. Follow the instructions here for the source chart: https://www.sierrachart.com/index.php?page=doc/ChangingFuturesContract.html#ChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
