Date/Time: Thu, 02 May 2024 03:05:58 +0000
How to combine future contracts files (intraday chart) at a prec
View Count: 2188
[2013-04-02 16:23:53] |
SoundsLikeSun - Posts: 30 |
Hi, Currently, I use the join feature as requested in the documentation. I understand that the switch is made whenever the new contract's volume exceed the volume of the previous file. However, I usually never trade a future contract on expiring day, because I want to avoid first notice. Therefore, I need to switch contract at the end of the day before expiring day, even if volumes haven't already exceeded the ones of the previous file (hope it's clear) So : 1- Is there a way to do it ? In the documentation, it seems only possible for historical charts 2- If, not, do you intend to enable it ? Thank you very much for your help Thomas |
[2013-04-02 16:25:36] |
For backtesting purposes, I need the datas to be as I trade them, hence my question Thank you |
[2013-04-03 07:53:06] |
1, 2. Yes. This is under development and will be ready by the end of next week at the latest.
[2013-04-03 09:12:32] |
Great Thank you for your fast answer |
