Date/Time: Thu, 16 May 2024 04:48:40 +0000
Can a file selection study input be added to ACSIL
View Count: 667
[2017-03-08 14:37:39] |
@sstfrederik - Posts: 403 |
Hi would like to work with local files within SC studies. An a file selection input be supported? Thanks, Frederik |
[2017-03-08 18:09:14] |
No. You would have to use the text string Input and manually specify the file name: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_scInputs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-08 18:38:56] |
Ok. I knew that. A while back in this post it was offered to be added, so I thought I'd ask again. Read local file in ACSIL |
[2017-03-11 22:45:42] |
Actually this was on our task list and has now been done and released in version 1528.
