Date/Time: Sat, 07 Nov 2026 11:04:32 +0000
Incorrectly Sized Label
View Count: 875
| [2017-03-01 07:15:43] |
| CarlRostron - Posts: 80 |
Just to bring this to your attention, see image Thanks |
| [2017-03-01 08:18:22] |
Yes, that is something we are aware of. Not everyone will see that but it has been corrected. If you update to the latest prerelease with Help >> Download Prerelease it will look correct on your system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
