Date/Time: Mon, 29 Apr 2024 07:05:46 +0000
[Programming Help] - Reading/Calculating "Valley" prices from VbP Study
View Count: 1020
[2017-02-28 14:41:08] |
Sporken - Posts: 82 |
Hi, In ACSIL, is it possible to get the price values of the Valleys from the "Volume By Price" study? I've tried using Study/Price Overlays and Study Subgraph references and I've tried in ACSIL using sc.GetStudyArrayFromChartUsingID(), sc.ChartDrawingExists and GetUserDrawnChartDrawing(). I can't find the source for the Volume By Price study in the ACS sources folder. I think I probably need to write an ACSIL study to calculate these valley prices. Are there any examples I should look at? I see VAPContainer.h, is this the best place to start? I am very happy to pay for your support with this as it obviously goes beyond the scope of a normal support issue. Any assistance is greatly appreciated. Kind Regards, -Jason |
[2017-02-28 17:26:50] |
Hi, I did some more searches of your support site and found the following section. https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#ProgrammaticallyAccessingVolumeAtPriceData I think this is what I was looking for and unfortunately I think it says I'm not able to get those values from the study itself. |
[2017-02-28 17:29:57] |
This led me to this section which I am now reading ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars |
[2017-02-28 19:15:35] |
In ACSIL, is it possible to get the price values of the Valleys from the "Volume By Price" study? This data is not programmatically accessible. You will need to calculate this using this data: ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-20 12:50:50] |
User978506 - Posts: 3 |
"This data is not programmatically accessible. You will need to calculate this using this data:" Can you provide the code |
[2023-06-20 12:59:45] |
Sierra_Chart Engineering - Posts: 14126 |
Provide the code for what?
[2023-07-05 22:25:33] |
Dean Roberts - Posts: 79 |
I'm trying to get Valley values from a Volume Profile as well and trying to create a custom study using the function below from the studies2.cpp file. The below function negates the use of the sc.volumeatpriceforbars function doesn't it? sc.GetStudyPeakValleyLine example function ----------------------------------------------------------------------------*/ SCSFExport scsf_GetStudyPeakValleyLineExample(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "GetStudyPeakValleyLine Example"; sc.AutoLoop = 0; sc.Input[0].SetStudyID(1); sc.Input[0].Name = "Volume by Price Study"; return; } // Do data processing float PeakValleyLinePrice= 0; int PeakValleyType = 0; int StartIndex = 0; int PeakValleyExtensionChartColumnEndIndex = 0; // get the first Peak/Valley line from the last volume by price profile if (sc.GetStudyPeakValleyLine(sc.ChartNumber, sc.Input[0].GetStudyID(0), PeakValleyLinePrice, PeakValleyType, StartIndex, PeakValleyExtensionChartColumnEndIndex, -1, 0)) { // Peak/Valley line found int Test = 1; } |
[2023-07-06 03:15:46] |
It is using this function which has a particular purpose: sc.GetStudyPeakValleyLine If this is all that you need, this is all that you need. It is that simple. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-06 03:15:58
[2023-07-07 07:43:49] |
User407375 - Posts: 10 |
Dean, in case you didn't notice - when implementing this you will likely want a loop to increment the "PeakValleyIndex" argument to sc.GetStudyPeakValleyLine to extract all of the valleys. For example: for (int i = 0; ; i++) {
if (sc.GetStudyPeakValleyLine(sc.ChartNumber, sc.Input[0].GetStudyID(0), PeakValleyLinePrice, PeakValleyType, StartIndex, PeakValleyExtensionChartColumnEndIndex, -1, i)) { if (PeakValleyType == PEAKVALLEYTYPE_VALLEY) { // Do whatever you want with PeakValleyLinePrice } } else break; } Date Time Of Last Edit: 2023-07-07 10:54:10
