Date/Time: Fri, 10 May 2024 15:56:17 +0000
NASDAQ100
View Count: 606
[2017-02-27 20:04:00] |
User865738 - Posts: 16 |
Hi, I need to help with nasdaq100 index real time data. I want this data from sierra chart. I don´t know to find nasdaq100 index (no futures) in your offer (in which group it is). Or you don´t provide real time data for NQ100 index? I have it in my SC, but it´s historical data. Please help mi with activate this data if it´s possible and tell mi where I can activate it (in which group and under what name/symbol. Thank you to your help. |
[2017-02-27 22:00:02] |
You need to activate the NASDAQ Indices exchange. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges The symbol is: $IUXX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-28 16:49:06] |
Ok, thank you, I found it. But there are data which do not include Market Depth. Can I have this data with market depth? Or we not provide it? |
[2017-02-28 18:36:13] |
Market depth data is only provided for futures symbols.
