Date/Time: Sat, 14 Nov 2026 03:03:33 +0000
ALERT SOUND PROBLEM
View Count: 943
[2017-02-27 00:30:49]
raja - Posts: 20
i did set the correct alert no
it still keeps playing prev alert sound
bala
[2017-02-27 01:06:13]
What specifically is generating the alert?
And what is the Alert Sound setting for it set to?
[2017-02-27 01:15:22]
raja - Posts: 20
the alert is in a study
say it is set to alert 1
in global settings i have selected a wav
file (third party wav file) to play for
alert 1
i tested it - works fine there
but in the study alert 1 plays the prev wav file
[2017-02-27 02:21:52]
When you say "previous wav file" what specifically are you referring to?
[2017-02-27 03:02:09]
raja - Posts: 20
prev wav file = i used sierra's built in sound file
in the alert sounds folder
in that folder i copy pasted my third party wav file
[2017-02-27 18:33:29]
So long as you have assigned the correct sound file to the correct Alert Number in General Settings, there should not be any problem with this.
Here are instructions:
http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings
If you still have a problem we will need to get that sound file you are working with and we can test it.
