Date/Time: Sat, 04 May 2024 14:19:26 +0000
Have one dom in live and one in demo mode
View Count: 671
[2017-02-26 20:47:50] |
User554317 - Posts: 59 |
How can I operate one dom in live and another dom (on different pair) in demo mode please? Thank you |
[2017-02-26 21:57:38] |
You need to use another instance of Sierra Chart. The easiest way is with File >> New Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-26 23:27:53] |
Perfect, Thank you!
[2017-02-27 09:12:00] |
One more Question. How do I actually copy my dom settings over etc? It seems like they have reverted to default?
[2017-02-27 10:10:53] |
In newer versions of Sierra Chart these are saved as part of a Chartbook. So you need to copy a Chartbook from one instance to the other. For details, refer to: https://www.sierrachart.com/index.php?page=doc/Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-27 10:30:03] |
Ok thanks again!
