Date/Time: Tue, 07 May 2024 08:06:26 +0000
Overlay NYSE TICK on renko chart
View Count: 1414
[2017-02-26 12:19:07] |
User791219 - Posts: 2 |
Hi, I'm a relatively new user to Sierra. I'm looking to overlay the NYSE TICK on my 6 tick renko chart for the ES. As you can see from the image attached there's gaps in the data. I'm sure i'm overlooking something small - I have played around with the settings. NYSE TICK chart is set to 30 seconds. Any suggestions, please? I have used Market Delta in the past and I was able to overlay the TICK and Advance / Decline with no gaps or issues. Thanks, Tom http://www.sierrachart.com/image.php?Image=1488111458625.png |
[2017-02-27 18:47:23] |
Since the destination chart is a Renko chart, you need to use a different overlay study. Refer to: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#Overlaying We added a new paragraph describing this. However, in the case where you want to overlay a market statistics chart to a chart with variable timeframe bars (Number of Trades, Volume, Range, Reversal, Renko, Delta Volume, Price Change, Point and Figure bars), then use the Study Overlay - OHLC study instead. Set the chart bar period/timeframe in the market statistics chart to approximately 1/10 of the average time length of the variable timeframe bars in the destination chart. This is to create greatest accuracy with the overlaid destination chart bars.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-27 18:50:42
