Date/Time: Sun, 05 May 2024 06:27:11 +0000
Replay
View Count: 571
[2017-02-26 05:17:08] |
2garin - Posts: 184 |
Good day support. Why stopped working Replay (not called the panel, does not start Replay) in the 1522 version? |
[2017-02-26 08:43:20] |
If you do not see the replay window then you just need to make it visible with Window >> Reset Windows and then select Chart >> Replay Chart >> Replay Chart again.
