Date/Time: Sun, 05 May 2024 00:20:54 +0000
Can the Range Bar Predictor display like the Renko Bar Predictor
View Count: 746
[2017-02-24 21:44:02] |
mike327 - Posts: 10 |
The Renko Bar Predictor displays the Predicted High and Predicted Low lines above and below the current bar forming on the chart. The Range Bar Predictor displays the lines in the fill space. I looked in the code for each but could not find a difference. I was hoping for the Range Bar Predictor to display on the chart as the Renko Predictor does. Thanks in advance.
[2017-02-26 09:50:08] |
Both of these these display on the last bar. That is clear. It seems as though you might be using a Subgraph Displacement of 1 on the Range Bar Predictor. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-26 09:50:43
