Date/Time: Sat, 27 Apr 2024 18:27:01 +0000
Number Bars diagonal compare threshold and alerts
View Count: 1643
[2017-02-24 17:03:36] |
pappe88 - Posts: 22 |
Hello, is it possible to have an alert, when using number bars with diagonal compares? Id' like to have an alert when a bar closes which has atleast one column with a highlighted bid/ask value (green/red). Please habe a look at the attached screenshot. Thx! Regards |
Bildschirmfoto vom 2017-02-24 18-00-12.png / V - Attached On 2017-02-24 17:02:13 UTC - Size: 11.01 KB - 301 views |
[2017-02-24 18:10:15] |
Use the Volume at Price Threshold Alert V2 study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=386#Volume_At_Price_Threshold_Alert_V2 You will also need to update Sierra Chart to the latest version. Follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-24 20:02:45] |
That looks good! But unfortunately the volume threshold seems to not work when using precentage difference. So I get almost every new bar an alert. Please see attached my settings and my chart. As you can see I have to much threshold alert v2 squares :( On the number bars I work with a Bid/ask minimum Volume compare threshold of 90. Is there a way to use the volume threshold with percentage difference method? |
Bildschirmfoto vom 2017-02-24 20-58-59.png / V - Attached On 2017-02-24 20:00:00 UTC - Size: 43.26 KB - 476 views |
[2017-02-26 20:51:52] |
How is the Comparison Method input set? We cannot fully tell. Also update Sierra Chart to the latest release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-26 20:52:24
