Date/Time: Sat, 18 May 2024 05:24:48 +0000
Range Bar Modification Request
View Count: 2124
[2017-02-22 20:39:37] |
User963581 - Posts: 12 |
I use RANGE PER BAR - NEW BAR ON RANGE MET chart type and request one little modification. it must be OPEN= CLOSE as ( range per bar open=close ) This bar type is crucial as it closes the bar without one tick extention. Is it possible to add this style into bar types? It is every important for my trading setups. |
[2017-02-22 20:55:06] |
This is not something we would add. There are already too many range bar types and no one else has asked for this. And all of these are manipulating the actual values, except for one of them. You will need to find another program to meet your requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-22 21:07:24] |
Thank you for your kind answer and being helpful. Nobody asked for it, because % 95 of traders win, only losers ask. Sorry for interrupting. |
[2017-02-22 23:44:11] |
TechTrader - Posts: 116 |
User 963581 Chart > Chart Settings/Graph Draw Type, select Candlestick Body Only. |
[2017-02-24 00:18:46] |
Thank You TechTrader, You got the point . |
[2017-02-24 04:12:04] |
OK so if post #4 accomplishes what you want then that is good. We did not understand that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-24 04:12:28
[2017-02-24 14:27:38] |
Unfortunately It did not accomplish but it is still helpful. On Range bars, body relations are important. Open = previous close ( sierra has this ) Close = when the range it complete. ( No need to wait for one extra outside tick in order to close it ) Example = for 5 tick, when the 5 tick is reached, new bar begins - ( no need to wait for confirmation tick outside of this 5 tick range in order to start new bar) Screenshots are attached. 2 different other softwares . Date Time Of Last Edit: 2017-02-24 16:26:39
[2017-02-27 19:34:45] |
OK, but there is a lot of work to add a new range bar type, and we do not have any other requests for this.
[2017-03-08 00:05:47] |
Sawtooth - Posts: 4000 |
I would use this range bar type.
[2017-03-18 22:31:39] |
Thank you Tomgilb Ok , I am asking the community if anybody would get any benefit from this bar type ? If it looks beneficial for you, please let us know. Its a simple range bar and it has 2 simple features. 1-Open= Close of previous bar. ( therefore no gaps appear ) 2-When the range is completed , its done. It closes. There is no need to extend one more extra tick in order to be closed. Here is another example for YM chart, last friday. ( 5 ticks) To Support: I can pay for it if it is added as a bar type. Or if it can be done as a study, I am still interested , as long as it works with tick data. And all the community who is interested can use it. Date Time Of Last Edit: 2017-03-19 16:55:33
YM - Range Bars.png / V - Attached On 2017-03-18 22:30:58 UTC - Size: 35.13 KB - 390 views |
[2017-03-19 03:27:40] |
Support - I could use this range bar type. User963581 By using the previous range bar close gives one point you are looking for but again only when an extra tick forms the start of the new bar. |
[2017-03-23 05:53:26] |
We will put this on our to do list, but we can make no promise when we can get to it. When we get to it, we will discuss the cost at that time if you are still interested. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-27 23:49:02] |
Ok. Let me know. I look forward to hearing from you. |
[2017-08-18 19:33:08] |
We are going to be able to get to this during the next 30 days.
[2017-08-19 02:01:37] |
This has been done months ago Bar Period Type Range Per Bar-Open=Close(in ticks) |
[2017-08-19 03:36:37] |
I wasn't aware of it. Thank you Tech Trader and Support.
[2017-10-22 09:24:54] |
But that is not exactly what you are looking for. That has been released at least a couple of years. It is nothing new. This is what you want: I use RANGE PER BAR - NEW BAR ON RANGE MET chart type and request one little modification. it must be OPEN= CLOSE as ( range per bar open=close )
We can do this, and there is no extra cost since we are now working on chart bars. Let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-22 22:14:08] |
+1
Date Time Of Last Edit: 2017-10-22 22:14:45
[2017-10-22 22:56:32] |
ganz - Posts: 1048 |
+1User963581 Nobody asked for it, because % 95 of traders win, only losers ask.
You are asking for a filter to modify T&S.So this is no more then a private opinion to see one of thousands cases. -1 Date Time Of Last Edit: 2017-10-22 22:57:01
[2017-10-24 03:45:03] |
ertrader - Posts: 648 |
+1
[2017-10-24 13:07:43] |
If it can be done, I would be appreciate. Thank you
