Date/Time: Mon, 29 Apr 2024 20:20:16 +0000
Remote Build - issue
View Count: 674
[2017-02-22 12:05:41] |
sampater - Posts: 243 |
There is an issue with a compilation by Remote Build: -- Starting remote build of Custom Studies Source files: MyStudy.cpp. -- 12:57:12
Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: MyStudy.cpp:9:22: fatal error: drawings.h: No such file or directory #include "drawings.h" ^ compilation terminated. -- End of Build -- 12:57:15 The compilation the same file by option Build Custom Studies DLL is okey: -- Starting build of Custom Studies Source files: MyStudy.cpp. -- 12:57:40
C:\Windows\system32\cmd.exe /C "D:\SierraChart\ACS_Source\VisualCCompile.Bat" D:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" MyStudy.cpp Creating library MyStudy.lib and object MyStudy.exp Generating code Finished generating code -- End of Build -- 12:57:54 |
[2017-02-22 16:05:12] |
Sierra Chart - Max - Posts: 5597 |
As the error indicates the issue is that the drawings.h file is not available on the remote server. I can see that it is not possible to upload the .h file at the moment, this should be resolved in the next release of Sierra Chart. Sierra Chart Support |
[2018-06-21 23:41:14] |
User129630 - Posts: 22 |
I'm following up this old thread (a year and half old now). The Remote Build still cannot compile a local include file such as .h. Is this going to be fixed soon?
[2018-06-22 14:28:31] |
Apparently this particular issue was not brought to the attention of Sierra Chart engineering. We are resolving it now.
