Date/Time: Sun, 27 Sep 2026 08:39:15 +0000
[User Discussion] - Spreadsheet Study for trading Question
View Count: 938
[2017-02-21 21:24:10]
User352023 - Posts: 20
I am trying to do a backtest for a simple strategy which has a target value calculated from the buy entry bar. I am getting the buy entry but the issue I am having is with the buy exit.
Since the target is calculated on the bar that triggered the buy entry, I need to look up some values from that row to exit. What is the best way to lookup study values on the candle that generated the buy entry.
Thank you
[2017-02-22 00:37:30]
Sawtooth - Posts: 4354
Here's one way:
=IF(K3,Q3,S4)
Where the formula in is S3, the lookup is in column Q, and the entry is in column K.
Here's another way that gives the same result:
=INDEX(Q3:Q1002,MATCH(1,K3:K1002,0),1)
This doesn't have to be in a Formula Column if you only need the most recent entry's corresponding value, and you only need the value in one non-repeating cell.
[2017-02-22 03:44:52]
You just simply need to reference them.
Refer to:
Working with Spreadsheets: Cell and Range References
The study values would be on the very same row as the row that the buy entry occurred at.
