Date/Time: Fri, 03 May 2024 09:31:40 +0000
new account
View Count: 585
[2017-02-21 19:46:39] |
User568548 - Posts: 4 |
Hi, I have a new account by the AMP futures.I will be trading with Sierra Chart. I allreday use sierra chart and i will continuoue with my charts data in sierra. Is this possibble? What should i do? Thank's for help. |
[2017-02-22 04:34:09] |
Yes. You can use your Sierra Chart account with AMP. Refer to the relevant set of instructions here for Rithmic or CQG depending upon what you will be using through them: Rithmic Trading Platform Service CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-23 22:52:43] |
Hi, I connected with CQG but although I paid for package 5, I can not use tools like TPO, DVP, Number bars etc which should be included in package 5. Can you adapt my package 5 to my CQG connection? Thanks |
[2017-02-24 00:43:01] |
We see your Sierra Chart account is on service package 3. Follow the instructions below to change to service package 5: To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package". The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-26 15:08:09] |
Hi, I changed it already. But the problem is I have two Sierra accounts. One is my original account with account name surel07 with the package 5, the other one is the 14 day trial account with the account number 619752 which I currently trade. What I want is that I want my package 5 in my trading account 619752. Can you make the necessary adjustments? Thanks |
[2017-02-26 22:14:04] |
What is the Sierra Chart Account Name of the account you want to change to service package 5? You can find that under Help >> About within that instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-26 22:37:11] |
User556062 - Posts: 2 |
Account name AC108923
[2017-02-26 22:43:49] |
In this particular case you need to contact the broker and have them change the service package to 5. This is something we cannot do from our side.
[2017-02-26 22:49:12] |
ok. Thanks |
