Date/Time: Fri, 10 May 2024 12:15:59 +0000
Connection problem with poloniex (bitsouk)
View Count: 1061
[2017-02-17 02:50:50] |
User549046 - Posts: 3 |
I couldn't get connected, kindly have a look at the logs below thanks Poloniex Crypto Currency Exchange - DTC | Connecting to the server dtc.bitsouk.com. Port 5573 | 2017-02-14 03:38:47 DTC Client (0) | Resolved address bitsouk.com to IP 52.48.47.23. | 2017-02-14 03:38:48 DTC Client (55) | Error received in OnConnect while connecting. Windows error code 10061: Connection refused. | 2017-02-14 03:38:48 DTC Client (55) | Shutdown error. Unknown Windows error code 10058. | 2017-02-14 03:38:48 * DTC Client (55) | Shutdown and closed. | 2017-02-14 03:38:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-02-14 03:38:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-02-14 03:38:48 Poloniex Crypto Currency Exchange - DTC | Disconnected. | 2017-02-14 03:38:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-02-14 03:38:48 |
[2017-02-17 03:02:48] |
The Poloniex service is provided by an outside developer and it is not currently available.
