Date/Time: Sat, 11 May 2024 05:47:44 +0000
study not found in newer builds ?
View Count: 615
[2017-02-16 13:23:16] |
zippyzip - Posts: 293 |
this is not a big deal because its working but i want to know why im getting this wrror message that the ECI vwap 1.4 is not found , as its in the user contributed studies that comes with sierra
2017-02-16_08-19.jpg / V - Attached On 2017-02-16 13:22:50 UTC - Size: 11.31 KB - 224 views 2017-02-16_08-21.jpg / V - Attached On 2017-02-16 13:22:55 UTC - Size: 35.26 KB - 230 views |
[2017-02-16 17:53:44] |
That error message indicates the study is not being referenced from User Contributed Studies but a separate DLL file. Remove it from the chart and add it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
