Date/Time: Sun, 12 May 2024 04:40:52 +0000
SC Backup
View Count: 767
[2017-02-16 00:03:06] |
User687828 - Posts: 17 |
I would like to backup the entire SC. Layouts, colors, alerts, tools, DOM settings etc. I saw two replies on this, one was: Backing up Sierra Chart is as simple as backing up the folder that Sierra Chart is installed to. And the other referencing: http://www.sierrachart.com/index.php?page=doc/helpdetails15.html So which answer should I follow? The purpose is to copy everything to a backup machine and also for speedy recovery in case of hardware failure.
[2017-02-16 03:06:42] |
Do this: Backing up Sierra Chart is as simple as backing up the folder that Sierra Chart is installed to.
