Date/Time: Mon, 13 May 2024 03:56:42 +0000
Overlay one volume profile over another
View Count: 1786
[2017-02-15 22:09:46] |
User252419 - Posts: 235 |
How can I overlay one volume profile over another volume profile? I've aligned to far right both profiles and set Do Not Overlap DOM Graph to No but I still have one profile on the right and another profile a little bit more to the left next to the profile from the right. Thank you, |
[2017-02-16 05:37:52] |
Follow the instructions here to post an image of the chart as you currently have it so we can understand this as best as possible. Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-16 11:14:55] |
I want one profile over the other. Thank you, http://www.sierrachart.com/image.php?Image=1487243647384.png |
[2017-02-16 17:44:32] |
You really need to spend time reading the documentation. This is the relevant Input setting: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AllowSideBySideProfilesRSide Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
