Date/Time: Sat, 11 May 2024 06:46:09 +0000
Where is the market depth?
View Count: 765
[2017-02-15 01:59:46] |
User687828 - Posts: 17 |
Hello, I'm not seeing market depth or bid/ask and last qty in the DOM. How to enable these? Thanks. Date Time Of Last Edit: 2017-02-15 02:00:11
SierraChart_2017-02-15_08-58-33.png / V - Attached On 2017-02-15 02:00:07 UTC - Size: 43.79 KB - 265 views |
[2017-02-15 04:53:48] |
Refer to: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-15 05:00:26] |
I've tried that, I still don't see those columns.
SierraChart_2017-02-15_11-55-49.png / V - Attached On 2017-02-15 04:56:13 UTC - Size: 33.27 KB - 256 views Attachment Deleted. SierraChart_2017-02-15_11-57-36.png / V - Attached On 2017-02-15 04:59:53 UTC - Size: 51.96 KB - 261 views |
[2017-02-15 05:19:07] |
Go to Chart >> Open Market Depth Window. Do you see the market depth data there?
[2017-02-15 05:22:41] |
Yes.
SierraChart_2017-02-15_12-22-03.png / V - Attached On 2017-02-15 05:22:24 UTC - Size: 21.56 KB - 255 views |
[2017-02-15 05:44:01] |
Go to the Trade DOM itself and select Trade >> Customize Trade DOM Columns. Although we need to look into this. There is another command for the Chart but there should only be one of them now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-15 05:57:08] |
That worked. Thanks.
