Date/Time: Sun, 12 May 2024 11:59:01 +0000
Web Service Response
View Count: 810
[2017-02-15 01:08:55] |
User104854 - Posts: 441 |
I've gotten this error message a few times today. Never had this come up before. I looked it up but couldn't find what it is that I need to do. Can you help? Thank you.
[2017-02-15 01:12:51] |
Where are you seeing this? If it is in the Sierra Chart Message Log, then provide a copy following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-15 14:12:01] |
It showed up in the alert manager. I've attached an image.
Alert Manager.png / V - Attached On 2017-02-15 14:11:21 UTC - Size: 220.76 KB - 221 views |
[2017-02-15 15:55:47] |
I have alerts when I get filled, hit a target, etc. It's happening when one of these events happen. I haven't had an issue with this before. Is there a way to not have the alert window show up when it happens? It doesn't appear to be a serious problem. I just don't want this alert window popping up every time I get filled.
[2017-02-15 17:52:19] |
You need to scroll the Alerts Log horizontally to actually see the text of the Web service response.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-15 17:52:40
