Date/Time: Sun, 12 May 2024 00:38:55 +0000
Chart data incorrect
View Count: 586
[2017-02-15 01:07:36] |
User687828 - Posts: 17 |
Hello, I'm testing Sierra Chart as an alternative to Multicharts. I installed, connected and created a chart. The candles however appear incorrect, you can see the multiple duplicate candles throughout the chart. The chart is a tick chart so that affects the shapes of all the following candles. I attached also a screenshot from Multi for comparison. Please Help. Thanks, |
SierraChart_2017-02-15_07-51-41.png / V - Attached On 2017-02-15 01:06:48 UTC - Size: 61.46 KB - 235 views MultiCharts64_2017-02-15_07-55-30.png / V - Attached On 2017-02-15 01:06:58 UTC - Size: 58.3 KB - 221 views |
[2017-02-15 01:11:27] |
You need to set Sierra Chart to a tick by tick data configuration. This is explained in this help topic: http://www.sierrachart.com/index.php?page=doc/helpdetails47.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
