Date/Time: Tue, 07 May 2024 19:10:26 +0000
[User Discussion] - How do I reference spreadsheet values from a custom study?
View Count: 1434
[2013-08-13 03:40:38] |
Bedhog - Posts: 168 |
Hello All, I would like to draw some horizontal lines on a chart. All of the values I want to work with are in a spreadsheet. Can someone point me to the documentation on referencing spreadsheet data from a custom study? I could also use a hand with the 'if then' structure as shown. I was able to start this project using the sample line drawing found here sc.Subgraph[0].Name = "Line"; sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE; sc.Subgraph[0].PrimaryColor = RGB(0,255,0); // green sc.Subgraph[0].LineWidth = 5; sc.Input[0].Name = "Line Value"; sc.Input[0].SetFloat(50); // default value sc.Input[0].SetFloatLimits(1, 20000); // min-max value However, I would like to pull the the colors and the values from a spreadsheet. Line Value = SpreadsheetReference // '8Range'!AO3 If Spreadsheet1.!tabname.BL3 = 1 // '8Range'!AZ3 then Line Color = RGB(0,255,0); //green Else If Spreadsheet1.!tabname.BM3 = 1 then Line Color = RGB(255,0,0); //red Else If Spreadsheet1.!tabname.BN3 = 1 then Line Color = RGB(255,255,255); //white End Thank you. |
[2013-08-14 00:24:07] |
This is not supported. However, it is possible to access the Subgraph data from a Spreadsheet study on the chart. You can use this function: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members.html#scGetStudyArrayUsingID Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-31 23:35:34] |
I'm revisiting this topic and am still stumped. Perhaps somebody can tell me if it's already been done. I would like to know the 'cumulative delta - volume' beginning the moment of a trade entry. FulcrumTrader suggested to draw a horizontal line on the Cumulative Delta Bars, and this would work, but I'd like to automate it. I have the Horizontal Line at Time code from Studies6.cpp and just need to plug-in the trade entry time. :) |
