Date/Time: Tue, 14 May 2024 21:21:39 +0000
[User Discussion] - Rockwell Trading
View Count: 1189
[2017-02-14 16:19:39] |
User297539 - Posts: 55 |
Hello SC I downloaded file Rockwell me and liked to run it automatically. But I need help how I can set my buy and sell orders are executed automatically? I've tried using study "Trading Cross Over Example" but that doesn't work for me. I would like to just say, sell in the red area and close in the black area position us to join in the green area of buying, in the black area. Is possible to adjust it or it would have to be reprogrammed everything? |
14-02-2017 16-58-07.jpg / V - Attached On 2017-02-14 16:19:14 UTC - Size: 493.86 KB - 264 views |
[2017-02-15 15:56:40] |
Does anyone have an idea how I can do it, so that my positions are automatically opened and closed?
[2017-02-15 17:49:37] |
Trader&Hunter - Posts: 129 |
you need to create a spreadsheet I assume with automation
[2017-02-15 17:51:39] |
This question is not within the scope of Sierra Chart Support.
