Date/Time: Tue, 21 May 2024 17:12:30 +0000
Windows error code 14001 - custom study dll
View Count: 1079
[2017-02-04 18:21:27] |
maxima120 - Posts: 144 |
I haven't used some of my old studies for few years.. I just tried to add them to a chat. And good half of the dlls show : DLL load error. Windows error code 14001. What should I do to bring them back? |
[2017-02-04 20:26:09] |
This error code means: "The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. " Sounds like you are using dynamic linking to external DLLs which are not present. Always use static linking. Further help on this is outside the scope of our support and you will need to consult other forums for help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
