Date/Time: Sun, 28 Apr 2024 14:29:52 +0000
Volume Stop
View Count: 1529
[2013-04-02 11:44:23] |
A.J. - Posts: 20 |
Dear Sirs, is it possible to work with Volume Stops as well, means, the stop is not already triggered when 1 contract hits the Stop Level but will only be triggered when for eg. over 22 contracts (# adjustable) hit the Stop Level. Thank you very much for your support and time in advance! Best regards, Alexander |
[2018-01-26 18:13:03] |
Clef - Posts: 11 |
I also want to request addition of volume stop feature to Sierra's trading platform, as earlier requested by User30940. This type of stop loss strategy is becoming quite common in futures trading.
[2018-01-26 18:53:12] |
It is interesting you ask about this, because we are actually working on functionality like this now. We will add this as well. It should be out on Monday. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-26 18:53:26
[2018-01-26 20:47:27] |
Clef - Posts: 11 |
Awesome! You guys rock!
[2018-01-28 06:06:28] |
Acro - Posts: 436 |
Really looking forward to this new stop type
[2018-01-28 14:50:51] |
Usermb - Posts: 126 |
This is awesome!
[2018-01-30 08:16:02] |
Version 1694 with the built-in Trade Volume Triggered Stop order type is now available. This is the "Prerelease": Software Download: Fast Update Test it and let us know how it works. Make sure to use it only in Trade Simulation Mode until you know it works properly for you. It can be used as the main order or as an Attached Order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
