Date/Time: Mon, 06 May 2024 08:18:55 +0000
VbP issue
View Count: 1563
[2013-08-10 16:31:17] |
ganz - Posts: 1048 |
Hello SC Support There is an issue w VbP v1008 non-CLR Ticks per Volume Bar -> 1 Volume Graph Period Type -> Fixed by Bar Count Number of Bars for Fixed Bar Count -> 1 Extend Value Area -> is not working Extend Point Of Control -> is not working with best regards |
[2013-08-13 04:23:08] |
This is resolved.
[2013-08-13 05:59:27] |
Hello. v1009 The issue is still there. ty |
vbp_issue.StdyCollct - Attached On 2013-08-13 05:59:18 UTC - Size: 9.39 KB - 459 views |
[2013-08-13 06:19:08] |
We had thought you were not using Extend Until Future Intersection. We did resolve a problem with extending the value area and point of control until the end of the period when the profile only covers a single bar. We will update the documentation to indicate that when using Fixed by Bar Count, that you cannot extend the Value Area and Point of Control until future intersection. The inherent problem with this, it would be far too inefficient with how this is accomplished. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-13 06:20:39
