Date/Time: Mon, 29 Apr 2024 16:30:55 +0000
Introducing brokers for LMAX
View Count: 2390
[2017-02-03 16:19:38] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
Hello, Optimus has ceased to work with LMAX. Can someone recommend another IB ?
[2017-02-03 18:04:34] |
Yes. You could just go direct with LMAX. Contact them directly about this.
[2017-02-07 07:20:07] |
LMAX won't recommend IBs while saying there are plenty. I am searching for one offering 20% rebates (or 15% at least) on commissions and $1000 minimum deposit. If anyone has a valid contact, please share |
[2017-02-08 05:24:51] |
AndyL - Posts: 119 |
You can have a look at fxmtf.com
[2019-02-16 04:14:32] |
User733644 - Posts: 6 |
I'm also looking for one. Did the OP find what he is looking for?
[2019-02-18 00:03:36] |
AlexPereira - Posts: 197 |
I created my account through fxmtf.com. Its also minimum $1000 deposit and FX, BULLION, ENERGY CFDs: 0.0020% of the notional traded in the second named currency ( as opposed to 0.0025% from LMAX ) Date Time Of Last Edit: 2019-02-18 00:05:36
